Any guesses?
Thanks Ron, Thats what I was guessing, ...would make a neat collectable for the Philco Bench. Dont worry, I'm not planning on bidding on it and I wont tell anyone else about it
8) .
Any guesses? - by Jerry Huelsbeck - 11-09-2005, 11:05 PM
[No subject] - by Ron Ramirez - 11-09-2005, 11:40 PM
[No subject] - by Jerry Huelsbeck - 11-10-2005, 03:36 AM
[No subject] - by Chuck Schwark - 11-10-2005, 09:41 AM
[No subject] - by Ron Ramirez - 11-10-2005, 10:58 AM
[No subject] - by Ron Ramirez - 11-13-2005, 12:36 AM
[No subject] - by Guest - 11-13-2005, 01:33 AM
[No subject] - by Chuck Schwark - 11-13-2005, 12:48 PM
[No subject] - by Guest - 11-13-2005, 01:19 PM
[No subject] - by Ron Ramirez - 11-13-2005, 01:29 PM
[No subject] - by Chuck Schwark - 11-13-2005, 03:04 PM
[No subject] - by Chuck Schwark - 11-13-2005, 03:18 PM
[No subject] - by Ron Ramirez - 11-13-2005, 03:28 PM
[No subject] - by Guest - 11-13-2005, 04:05 PM
[No subject] - by Guest - 11-20-2005, 06:20 PM
[No subject] - by Chuck Schwark - 11-20-2005, 08:31 PM
[No subject] - by Terry Judkins - 11-20-2005, 10:58 PM
[No subject] - by Chuck Schwark - 11-20-2005, 11:30 PM
[No subject] - by Guest - 11-27-2005, 07:45 PM
Philco 91 Tuning Condenser
There are currently 6863 online users. [Complete List]
» 2 Member(s) | 6861 Guest(s)
