Recent finds
Philco built lots of chairside models, but I think they gave them a different name. One unfortunate thing is that they usually put low end chassis in the later chairside sets, like five and six tube jobs. I think that the best model from 1938 had a 38-7 chassis in it. It seems that most of the Philco chairside sets I've seen are older units like the 370 Lazyboy or the 71LZ Lazyboy.
Recent finds - by TA Forbes - 12-09-2012, 11:51 PM
RE: Recent finds - by Conelrad - 12-10-2012, 01:30 PM
RE: Recent finds - by Ron Ramirez - 12-10-2012, 04:46 PM
RE: Recent finds - by 7estatdef - 12-10-2012, 05:53 PM
RE: Recent finds - by Jayce - 12-10-2012, 10:24 PM
RE: Recent finds - by Arran - 12-11-2012, 03:51 AM
RE: Recent finds - by Gene Pederson - 12-12-2012, 10:29 PM
RE: Recent finds - by TA Forbes - 12-13-2012, 01:11 PM
Philco 91 Tuning Condenser
There are currently 4077 online users. [Complete List]
» 1 Member(s) | 4076 Guest(s)
