Philco Predicta Princess Question
Hi Gary
I have never worked on a Predicta, believe it or not. If you are looking to remove the entire picture tube housing assembly from the cabinet, I suspect that might be a bit tricky.
A friend of mine has transported these intact for up to 100 miles with no problems. I think he laid his face down on a thick blanket.
Philco Predicta Princess Question - by n9vu - 08-08-2007, 10:18 PM
[No subject] - by Ron Ramirez - 08-09-2007, 05:41 PM
[No subject] - by Don Lind - 08-09-2007, 08:04 PM
[No subject] - by n9vu - 08-10-2007, 05:08 PM
