Philco37-60 starting
Obviously the 6Q7 needs changing, but also you say you
checked resistors, but did you replace even the ones that
checked "good"? A resistor can drift off/up once current
is flowing thru it. I, as a general rule, do not trust older
resistors any farther than I can throw them. I would
replace them to eliminate one variable.
Also, check the 6Q7 socket pins and a possible "open"
intermittant coil in the last IF can. Tapping around
with a wooden pencil and tapping wiring in that last
IF and DET stages may help.
Typing out loud,
Chuck
Philco37-60 starting - by jerryhawthorne - 12-07-2012, 07:37 PM
RE: Philco37-60 starting - by 7estatdef - 12-08-2012, 06:09 PM
RE: Philco37-60 starting - by ipwizard - 12-08-2012, 08:34 PM
Philco 37-60 update - by jerryhawthorne - 12-11-2012, 01:25 AM
RE: Philco37-60 starting - by Chuck Schwark - 12-11-2012, 10:21 AM
RE: Philco37-60 starting - by codefox1 - 12-11-2012, 01:59 PM
RE: Philco37-60 starting - by jerryhawthorne - 12-11-2012, 11:27 PM
RE: Philco37-60 starting - by codefox1 - 12-12-2012, 01:36 AM
Philco 91 Tuning Condenser
