Any guesses?
I believe that 012 uses the older "long box" style Shadow Meter and it won't work in all Shadow models, if someone wanted to used the guts to replace a defective meter in a radio.
Any guesses? - by Jerry Huelsbeck - 11-09-2005, 11:05 PM
[No subject] - by Ron Ramirez - 11-09-2005, 11:40 PM
[No subject] - by Jerry Huelsbeck - 11-10-2005, 03:36 AM
[No subject] - by Chuck Schwark - 11-10-2005, 09:41 AM
[No subject] - by Ron Ramirez - 11-10-2005, 10:58 AM
[No subject] - by Ron Ramirez - 11-13-2005, 12:36 AM
[No subject] - by Guest - 11-13-2005, 01:33 AM
[No subject] - by Chuck Schwark - 11-13-2005, 12:48 PM
[No subject] - by Guest - 11-13-2005, 01:19 PM
[No subject] - by Ron Ramirez - 11-13-2005, 01:29 PM
[No subject] - by Chuck Schwark - 11-13-2005, 03:04 PM
[No subject] - by Chuck Schwark - 11-13-2005, 03:18 PM
[No subject] - by Ron Ramirez - 11-13-2005, 03:28 PM
[No subject] - by Guest - 11-13-2005, 04:05 PM
[No subject] - by Guest - 11-20-2005, 06:20 PM
[No subject] - by Chuck Schwark - 11-20-2005, 08:31 PM
[No subject] - by Terry Judkins - 11-20-2005, 10:58 PM
[No subject] - by Chuck Schwark - 11-20-2005, 11:30 PM
[No subject] - by Guest - 11-27-2005, 07:45 PM
