Grunow 588
Time to show my ignorance/inexperience. What is the B- bar? Isn't it just ground on the chassis? This is an A/C radio.
From what I've found so far the plate voltages are all there but I can't seem to get any filament voltage readings but the tubes are hot. Any thoughts?
Eric
Eric
The Villages, FL
Grunow 588 - by Eric Adams - 12-12-2012, 01:19 PM
RE: Grunow 588 - by codefox1 - 12-12-2012, 01:53 PM
RE: Grunow 588 - by Eric Adams - 12-12-2012, 02:35 PM
RE: Grunow 588 - by Eric Adams - 12-12-2012, 06:25 PM
RE: Grunow 588 - by 7estatdef - 12-12-2012, 09:23 PM
RE: Grunow 588 - by Eric Adams - 12-13-2012, 12:41 AM
RE: Grunow 588 - by codefox1 - 12-13-2012, 02:42 AM
