37-630 (late version)mid chassis cap question
I use the Type 55 dial lamp in 1936, 37 & 38 Philcos. The large socket & collar assembly was designed for this bulb, and it gives out a bit better light than does the Type 44 in this application. The Type 44 should, as mentioned, be used as the shadowmeter lamp.
[No subject] - by Texasrocker - 08-04-2007, 08:09 PM
[No subject] - by Texasrocker - 08-09-2007, 10:23 PM
[No subject] - by Ron Ramirez - 08-09-2007, 10:44 PM
[No subject] - by Texasrocker - 08-09-2007, 11:17 PM
[No subject] - by Ron Ramirez - 08-09-2007, 11:42 PM
[No subject] - by Texasrocker - 08-10-2007, 12:29 AM
There are currently 3236 online users. [Complete List]
» 4 Member(s) | 3232 Guest(s)
AvatarAvatarAvatarAvatar
