Philco model 42-350t
Hi Ron,
Would you know where I can get an accurate schematic for this set?
So far I'm finding some that are close, but not the exact set.
The tube diagram on the sticker shows: 2)XXL, 2)7V7, 1)7B5, 1)7Y4, 1)XXFM.
These are what is in my set:
7A4s for XXLs-I know they substitute. 7B7s for the 7V7s. 7B5,7Y4 and I can't read any numbers on the last one.
Eric
The Villages, FL
Philco model 42-350t - by Eric Adams - 12-13-2012, 08:18 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-13-2012, 08:22 PM
RE: Philco model 42-350t - by Eric Adams - 12-13-2012, 08:28 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-13-2012, 08:36 PM
RE: Philco model 42-350t - by Eric Adams - 12-13-2012, 09:18 PM
RE: Philco model 42-350t - by Paul Philco322 - 12-13-2012, 10:05 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 04:19 PM
RE: Philco model 42-350t - by Chuck Schwark - 12-14-2012, 04:53 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-14-2012, 04:56 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 05:06 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-14-2012, 05:19 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 05:30 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 05:43 PM
RE: Philco model 42-350t - by kporter - 12-14-2012, 06:20 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-14-2012, 09:26 PM
RE: Philco model 42-350t - by Paul Philco322 - 12-18-2012, 09:03 AM
RE: Philco model 42-350t - by Eric Adams - 12-18-2012, 11:24 AM
RE: Philco model 42-350t - by Ron Ramirez - 12-18-2012, 11:34 AM
RE: Philco model 42-350t - by Paul Philco322 - 12-27-2012, 08:51 PM
RE: Philco model 42-350t - by codefox1 - 12-30-2012, 12:48 PM
RE: Philco model 42-350t - by Chuck Schwark - 12-31-2012, 08:33 PM
RE: Philco model 42-350t - by Eric Adams - 04-25-2013, 03:33 PM
RE: Philco model 42-350t - by Steve Davis - 04-25-2013, 04:59 PM
RE: Philco model 42-350t - by codefox1 - 04-25-2013, 09:43 PM
RE: Philco model 42-350t - by Eric Adams - 04-25-2013, 10:06 PM
RE: Philco model 42-350t - by codefox1 - 07-22-2013, 12:01 AM
RE: Philco model 42-350t - by Arran - 07-22-2013, 08:52 PM
RE: Philco model 42-350t - by Eric Adams - 07-23-2013, 01:22 AM
RE: Philco model 42-350t - by Eric Adams - 07-23-2013, 02:10 PM
RE: Philco model 42-350t - by Eric Adams - 07-23-2013, 06:02 PM
Philco 91 Tuning Condenser
There are currently 4656 online users. [Complete List]
» 2 Member(s) | 4654 Guest(s)
