Philco 15X Back panel and labels?
I used a pressed fiber board from home depot,forgot the name of the stuff,the thickness was just right,very durable,used a holesaw for all the holes,sanded smooth all edges. use your old cover for templet ,your lucky. i had to do mine from a picture ,took a while to get holes in the right place. then i spray painted it to match factory color from picture i used. then i used a black or brown if you like, window screen attached to inside of of your board , this worked very well ,looked factory this was done for my philco 23x that i restored over the summer and won first place,peoples choice award, and best of show, How about that. i sure did that old 23x proud as Tom Forbes had said. Merry Christmas to all from Fred and BIG Henry from DALLAS tx
Philco 15X Back panel and labels? - by Radioguy52 - 10-02-2012, 11:01 AM
RE: Philco 15X Back panel and labels? - by Arran - 10-03-2012, 01:41 AM
RE: Philco 15X Back panel and labels? - by Skip - 11-30-2012, 04:39 PM
RE: Philco 15X Back panel and labels? - by Skip - 11-30-2012, 09:19 PM
RE: Philco 15X Back panel and labels? - by Fred Taylor - 12-15-2012, 11:09 AM
New member
Philco 630csx power cord
New member
There are currently 3928 online users. [Complete List]
» 2 Member(s) | 3926 Guest(s)
