A Couple Of Rough "new" Philcos
These sets look pretty good to me. Not all that rough at all. You're going to enjoy them.
RE: A Couple Of Rough "new" Philcos - by Arran - 12-14-2012, 11:55 PM
RE: A Couple Of Rough "new" Philcos - by codefox1 - 12-15-2012, 12:41 PM
Philco 91 Tuning Condenser
