Packing and Shipping Radios
I'm purchasing a Philco Model 66B from a gentleman in the mid-west. I live in California. The radio measures approximately 16" high, 13" wide and 10" deep. Its approximate weight is 13 pounds.
Thanks!
Packing and Shipping Radios - by Allen in SB - 12-16-2012, 07:30 PM
RE: Packing and Shipping Radios - by 7estatdef - 12-16-2012, 07:34 PM
RE: Packing and Shipping Radios - by Allen in SB - 12-16-2012, 08:02 PM
RE: Packing and Shipping Radios - by Ron Ramirez - 12-20-2012, 10:00 AM
RE: Packing and Shipping Radios - by Ron Ramirez - 12-20-2012, 10:05 AM
RE: Packing and Shipping Radios - by codefox1 - 12-20-2012, 04:46 PM
RE: Packing and Shipping Radios - by Paul Knaack - 12-20-2012, 08:58 PM
RE: Packing and Shipping Radios - by Allen in SB - 12-21-2012, 12:27 AM
RE: Packing and Shipping Radios - by Ron Ramirez - 12-23-2012, 11:54 AM
RE: Packing and Shipping Radios - by codefox1 - 12-23-2012, 01:30 PM
RE: Packing and Shipping Radios - by wa2ise - 12-31-2012, 09:48 PM
Philco 91 Tuning Condenser
There are currently 5364 online users. [Complete List]
» 1 Member(s) | 5363 Guest(s)
