60cyc hum stromberg carlson
The one of the cap values was light should be 40 and it came in at 33 so I changed it seems to be better. the speaker is not original. Also I'm finding that the phono has a pretty good buzz when it's on I can soften it with the tone adj. will open up the amp and see what is in there. The print is in Riders 15-17
60cyc hum stromberg carlson - by Eric - 12-19-2012, 12:10 PM
RE: 60cyc hum stromberg carlson - by TA Forbes - 12-19-2012, 01:56 PM
RE: 60cyc hum stromberg carlson - by TA Forbes - 12-19-2012, 02:02 PM
RE: 60cyc hum stromberg carlson - by codefox1 - 12-19-2012, 02:19 PM
RE: 60cyc hum stromberg carlson - by TA Forbes - 12-19-2012, 02:29 PM
RE: 60cyc hum stromberg carlson - by Eric - 12-19-2012, 04:51 PM
RE: 60cyc hum stromberg carlson - by Arran - 12-19-2012, 11:12 PM
RE: 60cyc hum stromberg carlson - by TA Forbes - 12-19-2012, 11:29 PM
RE: 60cyc hum stromberg carlson - by Eric - 12-20-2012, 11:37 AM
RE: 60cyc hum stromberg carlson - by Arran - 12-20-2012, 09:40 PM
RE: 60cyc hum stromberg carlson - by 7estatdef - 12-21-2012, 08:50 AM
RE: 60cyc hum stromberg carlson - by Conelrad - 12-21-2012, 02:02 PM
RE: 60cyc hum stromberg carlson - by Eric - 12-21-2012, 06:55 PM
RE: 60cyc hum stromberg carlson - by codefox1 - 12-21-2012, 07:52 PM
RE: 60cyc hum stromberg carlson - by TA Forbes - 12-22-2012, 12:57 AM
