  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
Frank, you haven't posted in a few days. I might suggest a touch of the finger to the center tap of the volume control to see if the audio amp is working. Love that induced hum.
Jerry
RE: Growing up quick...with a 38-690xx Pics added. - by jerryhawthorne - 12-19-2012, 10:45 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
