  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
You wil be OK. Let us know what else you need.
RE: Growing up quick...with a 38-690xx Pics added. - by codefox1 - 12-20-2012, 01:38 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7096 online users. [Complete List]
» 1 Member(s) | 7095 Guest(s)
