Philco 531 advice needed.
531: http://www.philcoradio.com/gallery/1928.htm#f
Philco called this one a "Lowboy" even though it has long legs. Probably because this set is shorter than its big brother 551 which has even longer legs.
Yes, the 531 uses the same 7-tube chassis as the 511 series metal table models.
I really don't know what to suggest as to an offering price. Now, if that were a 551, I would be saying "BUY IT!!! BUY IT!!!" Because, the 551 version isn't seen very often.
Philco 531 advice needed. - by Jayce - 12-19-2012, 05:41 PM
RE: Philco 531 advice needed. - by TA Forbes - 12-19-2012, 11:17 PM
RE: Philco 531 advice needed. - by Arran - 12-20-2012, 01:27 AM
RE: Philco 531 advice needed. - by Jayce - 12-20-2012, 05:35 PM
RE: Philco 531 advice needed. - by codefox1 - 12-20-2012, 06:19 PM
RE: Philco 531 advice needed. - by Ron Ramirez - 12-20-2012, 06:24 PM
RE: Philco 531 advice needed. - by Jayce - 12-20-2012, 09:59 PM
RE: Philco 531 advice needed. - by Jayce - 12-21-2012, 05:51 PM
RE: Philco 531 advice needed. - by TA Forbes - 12-22-2012, 12:53 AM
RE: Philco 531 advice needed. - by Jayce - 12-22-2012, 03:57 PM
Philco 91 Tuning Condenser
