Packing and Shipping Radios
Ron and Codefox's packaging instructions are the way to go. The only thing I can add is to be sure the chassis and speaker is securely bolted to cabinet.
Packing and Shipping Radios - by Allen in SB - 12-16-2012, 07:30 PM
RE: Packing and Shipping Radios - by 7estatdef - 12-16-2012, 07:34 PM
RE: Packing and Shipping Radios - by Allen in SB - 12-16-2012, 08:02 PM
RE: Packing and Shipping Radios - by Ron Ramirez - 12-20-2012, 10:00 AM
RE: Packing and Shipping Radios - by Ron Ramirez - 12-20-2012, 10:05 AM
RE: Packing and Shipping Radios - by codefox1 - 12-20-2012, 04:46 PM
RE: Packing and Shipping Radios - by Paul Knaack - 12-20-2012, 08:58 PM
RE: Packing and Shipping Radios - by Allen in SB - 12-21-2012, 12:27 AM
RE: Packing and Shipping Radios - by Ron Ramirez - 12-23-2012, 11:54 AM
RE: Packing and Shipping Radios - by codefox1 - 12-23-2012, 01:30 PM
RE: Packing and Shipping Radios - by wa2ise - 12-31-2012, 09:48 PM
Philco 91 Tuning Condenser
