Philco 531 advice needed.
The 551 does look very nice. Oddly, I constantly run across model 87 Philcos, but that is it for early models around here. The table model he has is indeed a 511 and looks nice as well, but no speaker. Icon_sad He is wanting to find a broker or sight to privately sell off his radios in the near future and I'd like to snag this radio before he does. He has the rare chairside with the remote speaker as well, but now it's damaged because of a roof leak last winter. Icon_sad
Philco 531 advice needed. - by Jayce - 12-19-2012, 05:41 PM
RE: Philco 531 advice needed. - by TA Forbes - 12-19-2012, 11:17 PM
RE: Philco 531 advice needed. - by Arran - 12-20-2012, 01:27 AM
RE: Philco 531 advice needed. - by Jayce - 12-20-2012, 05:35 PM
RE: Philco 531 advice needed. - by codefox1 - 12-20-2012, 06:19 PM
RE: Philco 531 advice needed. - by Ron Ramirez - 12-20-2012, 06:24 PM
RE: Philco 531 advice needed. - by Jayce - 12-20-2012, 09:59 PM
RE: Philco 531 advice needed. - by Jayce - 12-21-2012, 05:51 PM
RE: Philco 531 advice needed. - by TA Forbes - 12-22-2012, 12:53 AM
RE: Philco 531 advice needed. - by Jayce - 12-22-2012, 03:57 PM
Philco 91 Tuning Condenser
