42-1008 code 122
My parts order has arrived.
I immediately got to work replacing resistors. I got to the 5th or 6th one and discovered that I should have read the Code 122 notes before ordering-- resistor (57) 2.2kOhm was replaced with a 3.3kOhm resistor, among other things.
That one will have to wait until I can get up to Radio Snark in the morning and pay too much after answering the clueless kid working there what he can help me find and then ignoring the blank look on his face (bless his heart).
Let that be a lesson to always read the notes for the set being worked on before ordering parts online.
42-1008 code 122 - by Eric T - 12-26-2010, 02:49 PM
RE: 42-1008 code 122 - by Eric T - 06-05-2012, 08:02 PM
RE: 42-1008 code 122 - by Michael Dennis - 06-05-2012, 08:20 PM
RE: 42-1008 code 122 - by Sean - 06-06-2012, 11:24 AM
RE: 42-1008 code 122 - by Eric T - 06-06-2012, 06:21 PM
RE: 42-1008 code 122 - by Eric T - 07-18-2012, 10:12 PM
RE: 42-1008 code 122 - by Eric T - 07-29-2012, 09:58 AM
RE: 42-1008 code 122 - by Eric T - 07-29-2012, 10:07 AM
RE: 42-1008 code 122 - by Eric T - 12-16-2012, 09:57 AM
RE: 42-1008 code 122 - by Eric T - 12-20-2012, 10:05 PM
RE: 42-1008 code 122 - by Eric T - 12-22-2012, 01:28 PM
RE: 42-1008 code 122 - by Eric T - 12-22-2012, 05:14 PM
RE: 42-1008 code 122 - by Ron Ramirez - 12-23-2012, 12:09 PM
RE: 42-1008 code 122 - by Eric T - 12-23-2012, 03:27 PM
RE: 42-1008 code 122 - by Eric T - 12-23-2012, 08:25 PM
RE: 42-1008 code 122 - by Eric T - 12-24-2012, 12:15 AM
RE: 42-1008 code 122 - by Eric T - 12-24-2012, 06:23 PM
RE: 42-1008 code 122 - by Eric T - 12-24-2012, 06:52 PM
RE: 42-1008 code 122 - by Ron Ramirez - 12-24-2012, 07:02 PM
RE: 42-1008 code 122 - by Eric T - 12-27-2012, 10:56 AM
RE: 42-1008 code 122 - by codefox1 - 12-27-2012, 04:36 PM
RE: 42-1008 code 122 - by Michael Dennis - 12-28-2012, 02:24 AM
RE: 42-1008 code 122 - by Eric T - 12-28-2012, 12:06 PM
RE: 42-1008 code 122 - by Eric T - 12-28-2012, 01:01 PM
RE: 42-1008 code 122 - by Eric T - 12-28-2012, 04:48 PM
RE: 42-1008 code 122 - by Ron Ramirez - 12-28-2012, 05:12 PM
RE: 42-1008 code 122 - by Ron Ramirez - 12-28-2012, 05:14 PM
RE: 42-1008 code 122 - by Eric T - 12-28-2012, 06:08 PM
RE: 42-1008 code 122 - by Eric T - 12-28-2012, 07:05 PM
RE: 42-1008 code 122 - by Ron Ramirez - 12-28-2012, 08:19 PM
RE: 42-1008 code 122 - by Eric T - 12-28-2012, 09:21 PM
RE: 42-1008 code 122 - by Eric T - 12-29-2012, 04:40 PM
RE: 42-1008 code 122 - by Eric T - 12-31-2012, 06:35 PM
RE: 42-1008 code 122 - by Eric T - 01-18-2013, 07:36 PM
RE: 42-1008 code 122 - by 7estatdef - 01-21-2013, 11:19 AM
RE: 42-1008 code 122 - by Eric T - 01-21-2013, 01:46 PM
RE: 42-1008 code 122 - by Eric T - 06-29-2013, 06:53 PM
RE: 42-1008 code 122 - by morzh - 06-29-2013, 10:02 PM
RE: 42-1008 code 122 - by Eric T - 06-30-2013, 05:39 PM
RE: 42-1008 code 122 - by morzh - 06-30-2013, 05:49 PM
RE: 42-1008 code 122 - by Eric T - 09-16-2013, 01:26 PM
RE: 42-1008 code 122 - by Eforrester - 11-22-2017, 11:52 PM
RE: 42-1008 code 122 - by Radioroslyn - 11-23-2017, 11:58 AM
RE: 42-1008 code 122 - by Eforrester - 11-30-2017, 12:38 PM
Re: 42-1008 code 122 - by 7estatdef - 12-26-2010, 04:07 PM
The speaker table error?
Philco 70 antenna lead
