Opinions On A 660X Please
Somebody has stripped the cabinet outright and painted the top black, probably to cover up a black ring or veneer damage. In any event it looks even less like a $150 radio and more like a garage sale special in that condition. I don't know what line of stupidity was behind connecting a power cord to the antenna and ground terminals but I would definitely test for continuity before even thinking of buying it, I always assume the worst when I see things like that.
Opinions On A 660X Please - by Gene Pederson - 12-21-2012, 04:35 PM
RE: Opinions On A 660X Please - by Arran - 12-21-2012, 08:35 PM
RE: Opinions On A 660X Please - by Gene Pederson - 12-21-2012, 08:44 PM
RE: Opinions On A 660X Please - by Arran - 12-21-2012, 08:52 PM
RE: Opinions On A 660X Please - by codefox1 - 12-22-2012, 01:54 AM
RE: Opinions On A 660X Please - by Gene Pederson - 12-22-2012, 08:05 PM
RE: Opinions On A 660X Please - by Ron Ramirez - 12-23-2012, 11:46 AM
RE: Opinions On A 660X Please - by Gene Pederson - 12-23-2012, 12:23 PM
RE: Opinions On A 660X Please - by TA Forbes - 12-23-2012, 03:36 PM
Philco 91 Tuning Condenser
