Philco Mod. #44" Need help"
Sorry Mike not the smartest on here but I assumed (you know what that means) that it was a big can on the top. Those underneath open up nice. I will attach a link to hopefully the right schematic. Never saw one of those carrying so many caps. As for the installation of the PM speaker as a replacement, it will or has had some changes to the original radio schematic most likely adding a large power resistor for the field coil and probably increased the value of the electrolyic caps. For those that wish to follow, I have attached the schematic.
Jerry
http://www.nostalgiaair.org/PagesByModel...013581.pdf
Philco Mod. #44" Need help" - by KCMike - 11-27-2012, 11:51 AM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-27-2012, 03:08 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-27-2012, 04:12 PM
RE: Philco Mod. #44" Need help" - by Steve Davis - 11-27-2012, 04:51 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-27-2012, 05:05 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-27-2012, 11:46 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-28-2012, 01:22 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-28-2012, 05:40 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-28-2012, 06:04 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-29-2012, 02:34 AM
RE: Philco Mod. #44" Need help" - by KCMike - 11-29-2012, 11:09 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-10-2012, 06:12 PM
RE: Philco Mod. #44" Need help" - by 7estatdef - 12-10-2012, 07:11 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-10-2012, 07:28 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-16-2012, 11:55 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 12-17-2012, 11:55 AM
RE: Philco Mod. #44" Need help" - by KCMike - 12-18-2012, 11:45 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 12-19-2012, 01:44 PM
RE: Philco Mod. #44" Need help" - by codefox1 - 12-19-2012, 02:30 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-19-2012, 04:01 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-20-2012, 12:29 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 07:59 PM
RE: Philco Mod. #44" Need help" - by jerryhawthorne - 12-22-2012, 08:24 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 08:26 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 08:56 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 09:37 PM
RE: Philco Mod. #44" Need help" - by Ron Ramirez - 12-31-2012, 05:54 PM
RE: Philco Mod. #44" Need help" - by KCMike - 01-01-2013, 04:02 PM
RE: Philco Mod. #44" Need help" - by codefox1 - 01-02-2013, 04:13 PM
RE: Philco Mod. #44" Need help" - by KCMike - 01-02-2013, 08:22 PM
RE: Philco Mod. #44" Need help" - by KCMike - 01-03-2013, 11:26 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3308 online users. [Complete List]
» 3 Member(s) | 3305 Guest(s)
