I am looking for a Zenith...maybe....with the tuning eye
Westinghouse didn't do anything but put their name on the front and market it, the set was made by American Bosch. The example that Morzh bought has also been stripped and refinished, note the matte finish with no grain filler, and no decals. The good news is that the cabinet is in good shape other then the one chipped knob and the cracked one, the cracked one can be glued of course. It's a fairly simple cabinet so refinishing it near factory condition should be easy, it doesn't have a complicated grille or moldings.
RE: I am looking for a Zenith...maybe....with the tuning eye - by Arran - 12-22-2012, 08:42 PM
There are currently 10606 online users. [Complete List]
» 3 Member(s) | 10603 Guest(s)
