Opinions On A 660X Please
Good! Icon_thumbup Icon_biggrin You will enjoy your 660. It's almost a 116 and just as powerful as a 116B in a console cabinet - the chassis are the same size, and very similar "under the hood" as well. The 660 has one less tube than the 116, though, and four bands instead of five.
Opinions On A 660X Please - by Gene Pederson - 12-21-2012, 04:35 PM
RE: Opinions On A 660X Please - by Arran - 12-21-2012, 08:35 PM
RE: Opinions On A 660X Please - by Gene Pederson - 12-21-2012, 08:44 PM
RE: Opinions On A 660X Please - by Arran - 12-21-2012, 08:52 PM
RE: Opinions On A 660X Please - by codefox1 - 12-22-2012, 01:54 AM
RE: Opinions On A 660X Please - by Gene Pederson - 12-22-2012, 08:05 PM
RE: Opinions On A 660X Please - by Ron Ramirez - 12-23-2012, 11:46 AM
RE: Opinions On A 660X Please - by Gene Pederson - 12-23-2012, 12:23 PM
RE: Opinions On A 660X Please - by TA Forbes - 12-23-2012, 03:36 PM
Philco 91 Tuning Condenser
