Zenith K725 Gone Belly Up
I have a dead Zenith K725(similar to H725). There's not even static on it and I'm assuming without testing as yet the SE-1 selenium rectifier is bad. Oddly enough, last night I had it playing, turned it off after about an hour and tried today and totally dead as if not even plugged in. The tubes do light but that's it. Any suggestions would be appreciated.
http://web.mit.edu/gr20603/www/website%2...01_192.pdf
Zenith K725 Gone Belly Up - by Elijah - 12-23-2012, 10:25 PM
RE: Zenith K725 Gone Belly Up - by TA Forbes - 12-24-2012, 11:02 AM
RE: Zenith K725 Gone Belly Up - by Elijah - 12-24-2012, 07:33 PM
RE: Zenith K725 Gone Belly Up - by TA Forbes - 12-24-2012, 10:02 PM
There are currently 9766 online users. [Complete List]
» 1 Member(s) | 9765 Guest(s)
