grill cloth philosophy question/PICS
This one suggests the pattern, but also looks too white.
http://www.ebay.com/itm/ANTIQUE-RADIO-GR...5aec7cf22a
RE: grill cloth philosophy question - by DKinYORKpa - 12-24-2012, 12:46 PM
RE: grill cloth philosophy question - by Arran - 12-24-2012, 08:02 PM
RE: grill cloth philosophy question - by DeckApe - 12-25-2012, 10:23 PM
Philco 91 Tuning Condenser
There are currently 5200 online users. [Complete List]
» 1 Member(s) | 5199 Guest(s)
