grill cloth philosophy question/PICS
Then again a diamond and square weave is a pretty popular pattern in drapery and upholstery fabrics anyhow, you may fine something suitable at a fabric store, though it won't be the same as the original. You may also have to dye the potential replacement cloth if the example happens to be the wrong colour.
RE: grill cloth philosophy question - by Arran - 12-24-2012, 08:02 PM
RE: grill cloth philosophy question - by DeckApe - 12-25-2012, 10:23 PM
Philco 91 Tuning Condenser
There are currently 5165 online users. [Complete List]
» 1 Member(s) | 5164 Guest(s)
