grill cloth philosophy question/PICS
So for fun, I dug out my old set of cloth samples from John. I see nothing that resembles a dark brown large diamond pattern. And the one that is called 1940 Philco large diamond, #27, is extremely close in pattern and weave, but overall is a light color. So, he either never had this pattern or copied the faded color. I doubt the latter.
RE: grill cloth philosophy question - by Arran - 12-24-2012, 08:02 PM
RE: grill cloth philosophy question - by DKinYORKpa - 12-25-2012, 11:51 AM
RE: grill cloth philosophy question - by DeckApe - 12-25-2012, 10:23 PM
Philco 91 Tuning Condenser
There are currently 5097 online users. [Complete List]
» 3 Member(s) | 5094 Guest(s)
