Philco 38-116 Question More Questions
So sorry to both of you for linking the wrong version, Ron your right it is a code 125 and I linked a 121 schematic. Thanks Ron for discovering that and solving the problem of a change later in notes that that resistor value was changed to a 4K from the original schematic. We are 3/4 through the cap changes and resistor checks and changes. We have "music". Not great but still need to through the IF section with many caps. Hope you and Arron have had a very nice holiday.
Jerry
RE: Philco 38-116 Question - by Arran - 12-25-2012, 01:15 AM
RE: Philco 38-116 Question - by Ron Ramirez - 12-25-2012, 08:49 AM
RE: Philco 38-116 Question - by jerryhawthorne - 12-25-2012, 02:16 PM
RE: Philco 38-116 Question - by Arran - 12-25-2012, 04:26 PM
RE: Philco 38-116 Question - by Ron Ramirez - 12-25-2012, 07:01 PM
RE: Philco 38-116 Question - by jerryhawthorne - 12-25-2012, 09:26 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3627 online users. [Complete List]
» 1 Member(s) | 3626 Guest(s)
