Philco Not Restored as Indicated in Ad
Make sure the cap is not in parallel with a winding in the coil or something else.
If coil is good recommend re-seal with glue. Not super glue.
RE: Philco Not Restored as Indicated in Ad - by TA Forbes - 12-25-2012, 10:51 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 4019 online users. [Complete List]
» 2 Member(s) | 4017 Guest(s)
