A Phalse Philco
Ford sold the PHILCO named to GTE-Sylvania in 1974. Sylvania, in turn, was later sold to Philips along with the PHILCO trademark and copy rights.This was ethically good and feasible in business world.
A Phalse Philco - by wa2ise - 10-14-2012, 05:37 PM
RE: A Phalse Philco - by Chuck Schwark - 10-14-2012, 07:56 PM
RE: A Phalse Philco - by Ron Ramirez - 10-14-2012, 08:12 PM
RE: A Phalse Philco - by Chuck Schwark - 10-14-2012, 08:59 PM
RE: A Phalse Philco - by flemiglee - 12-26-2012, 10:13 AM
Philco 91 Tuning Condenser
