tube numbering
Hi Guy's,
Does anyone know the numbering sequence on a number 42 tube(6 pin).
I need to know which is number one pin.
murf
tube numbering - by murf - 12-27-2012, 05:43 PM
RE: tube numbering - by LedHed - 12-27-2012, 05:50 PM
RE: tube numbering - by murf - 12-27-2012, 05:54 PM
RE: tube numbering - by Ron Ramirez - 12-27-2012, 08:04 PM
RE: tube numbering - by LedHed - 12-27-2012, 08:42 PM
RE: tube numbering - by codefox1 - 12-28-2012, 02:33 AM
RE: tube numbering - by TA Forbes - 12-28-2012, 10:42 AM
RE: tube numbering - by codefox1 - 12-29-2012, 02:53 PM
There are currently 10207 online users. [Complete List]
» 3 Member(s) | 10204 Guest(s)
