tube numbering
The two thick pins are 1 and 6. Pin one should be the thick one on the right viewed from the tube bottom IIRC.
One cannot forbid people to be idiots....all one can do is try not to be one. -Morzh
tube numbering - by murf - 12-27-2012, 05:43 PM
RE: tube numbering - by LedHed - 12-27-2012, 05:50 PM
RE: tube numbering - by murf - 12-27-2012, 05:54 PM
RE: tube numbering - by Ron Ramirez - 12-27-2012, 08:04 PM
RE: tube numbering - by LedHed - 12-27-2012, 08:42 PM
RE: tube numbering - by codefox1 - 12-28-2012, 02:33 AM
RE: tube numbering - by TA Forbes - 12-28-2012, 10:42 AM
RE: tube numbering - by codefox1 - 12-29-2012, 02:53 PM
There are currently 6328 online users. [Complete List]
» 2 Member(s) | 6326 Guest(s)
