Selenium Rectifier Replacement
I have another project radio, a Zenith Model Y723 that needs a new rectifier or preferably, a diode replacement. I looked on ebay for a NOS selenium rectifier to no avail. Zenith has several listed in their parts list such as a Federal 1101A or a Tarzian 100A but I couldn't' find these. The current rating is .071A.
Anyone know of the proper diode that will work with this set?
Selenium Rectifier Replacement - by Elijah - 12-29-2012, 01:10 PM
RE: Selenium Rectifier Replacement - by codefox1 - 12-29-2012, 02:47 PM
RE: Selenium Rectifier Replacement - by Elijah - 12-29-2012, 05:42 PM
RE: Selenium Rectifier Replacement - by codefox1 - 12-29-2012, 10:42 PM
RE: Selenium Rectifier Replacement - by Elijah - 12-30-2012, 11:41 AM
RE: Selenium Rectifier Replacement - by Elijah - 12-30-2012, 03:41 PM
There are currently 9904 online users. [Complete List]
» 3 Member(s) | 9901 Guest(s)
