40-215 opinions wanted
I think Arran pretty much summed it up for me. If you really like the set, I could see paying up to $100. $200? Naah, I would pass and wait for a better one at a lower price.
In fact, if you wait for Radiofest in August, you might find a better one there at 1/4 the price of this one. I do not know if there are any radio clubs in Wisconsin.
40-215 opinions wanted - by 37silverstreak - 12-29-2012, 01:54 PM
RE: 40-215 opinions wanted - by Arran - 12-29-2012, 09:33 PM
RE: 40-215 opinions wanted - by Ron Ramirez - 12-29-2012, 09:44 PM
RE: 40-215 opinions wanted - by Arran - 12-29-2012, 10:52 PM
RE: 40-215 opinions wanted - by 7estatdef - 12-31-2012, 11:05 AM
RE: 40-215 opinions wanted - by 37silverstreak - 01-01-2013, 06:37 PM
RE: 40-215 opinions wanted - by 7estatdef - 01-01-2013, 11:36 PM
Philco 91 Tuning Condenser
There are currently 4360 online users. [Complete List]
» 1 Member(s) | 4359 Guest(s)
