Selenium Rectifier Replacement
http://theschematicman.com/downloads.htm
Elijah Wrote:For some reason I'm not getting notifications via email of new posts and have to check periodically of new posts even though I'm subscribed to the thread.
See here for instructions:
http://philcoradio.com/phorum/showthread.php?tid=4390
The setting to receive notifications of new posts is not set by default, you have to set it yourself. I just set it for you, so you should receive these from now on.
Selenium Rectifier Replacement - by Elijah - 12-29-2012, 01:10 PM
RE: Selenium Rectifier Replacement - by codefox1 - 12-29-2012, 02:47 PM
RE: Selenium Rectifier Replacement - by Elijah - 12-29-2012, 05:42 PM
RE: Selenium Rectifier Replacement - by codefox1 - 12-29-2012, 10:42 PM
RE: Selenium Rectifier Replacement - by Elijah - 12-30-2012, 11:41 AM
RE: Selenium Rectifier Replacement - by Ron Ramirez - 12-30-2012, 12:59 PM
RE: Selenium Rectifier Replacement - by Elijah - 12-30-2012, 03:41 PM
There are currently 10532 online users. [Complete List]
» 2 Member(s) | 10530 Guest(s)
