12-30-2012, 03:54 PM
When I bought this radio from a radio person, he explained away the following note as "probably caps": 80 tube overheats, do not energize until problem is found. So I took out the 80, and did some voltage checks. The voltages to the 80 were right on. Filaments to the other tubes OK. Field coil OK, choke OK. So I stick the 80 in and at around 80 volts, there are little sparks on the 80 tube socket (from underneath) and I quickly shut down. The 80ST shows shorts and no filaments.. I hadn't checked it before this. Now, before I start the lengthy (but enjoyable
) recap, do my initial transformer checks rule out a transformer problem? Anything else to check first? Suspects?
What schematic do I want to be looking at? This chassis has a band switch; the on/off is with the volume. The electrolytics don't match up with 18 schematic. For example, I don't have part #s 59 & 60 (8uF & 10uF and 8uF), I have a 20/20/20 can.
