Philco 112 highboy found
Maybe I'll add the Philco 112 to my bucket list. Icon_smile
Philco 112 highboy found - by FStephenMasek - 12-24-2012, 03:13 PM
RE: Philco 112 highboy found - by Ron Ramirez - 12-24-2012, 03:20 PM
RE: Philco 112 highboy found - by Jayce - 12-24-2012, 05:00 PM
RE: Philco 112 highboy found - by Arran - 12-24-2012, 07:55 PM
RE: Philco 112 highboy found - by TA Forbes - 12-24-2012, 09:53 PM
RE: Philco 112 highboy found - by Jayce - 12-30-2012, 08:21 PM
Philco 91 Tuning Condenser
