what type is this?
A mid to late 1960s cabinet stereo, I can't tell you the brand off hand, they all pretty much look alike. In any event they don't tend to have much, if any value, at least the solid state ones, if it were a tube type Fisher it would be worth more, but still nothing outstanding. In this case it's in decent shape so someone may want it for a phonograph, or for a liquor cabinet conversion.
what type is this? - by raccrov1991 - 01-01-2013, 06:01 PM
RE: what type is this? - by Arran - 01-01-2013, 11:25 PM
RE: what type is this? - by AI2V - 01-02-2013, 12:50 PM
RE: what type is this? - by raccrov1991 - 01-02-2013, 01:56 PM
RE: what type is this? - by codefox1 - 01-02-2013, 03:57 PM
RE: what type is this? - by wa2ise - 01-02-2013, 08:54 PM
RE: what type is this? - by jerryhawthorne - 01-03-2013, 10:00 PM
Philco 91 Tuning Condenser
There are currently 5421 online users. [Complete List]
» 1 Member(s) | 5420 Guest(s)
