40-215 opinions wanted
On the 37-116 after you build the stand to hold the chassis upside down that half the battle. The other half is marking everything (wires on the RF deck) so you can get it back together right the first time. The rest is the same old replace all the cap and resistors on the RF deck and the caps on the rest. Check the resistors. Lots of fun!!!!
40-215 opinions wanted - by 37silverstreak - 12-29-2012, 01:54 PM
RE: 40-215 opinions wanted - by Arran - 12-29-2012, 09:33 PM
RE: 40-215 opinions wanted - by Ron Ramirez - 12-29-2012, 09:44 PM
RE: 40-215 opinions wanted - by Arran - 12-29-2012, 10:52 PM
RE: 40-215 opinions wanted - by 7estatdef - 12-31-2012, 11:05 AM
RE: 40-215 opinions wanted - by 37silverstreak - 01-01-2013, 06:37 PM
RE: 40-215 opinions wanted - by 7estatdef - 01-01-2013, 11:36 PM
Philco 91 Tuning Condenser
