what type is this?
If it uses a tube amplifier, the amp likely has some value to people over at audiokarma tube forum.
what type is this? - by raccrov1991 - 01-01-2013, 06:01 PM
RE: what type is this? - by Arran - 01-01-2013, 11:25 PM
RE: what type is this? - by AI2V - 01-02-2013, 12:50 PM
RE: what type is this? - by raccrov1991 - 01-02-2013, 01:56 PM
RE: what type is this? - by codefox1 - 01-02-2013, 03:57 PM
RE: what type is this? - by wa2ise - 01-02-2013, 08:54 PM
RE: what type is this? - by jerryhawthorne - 01-03-2013, 10:00 PM
Philco 91 Tuning Condenser
