New Philco 20 Filter Caps...In, but Another Question??
If radio has not been re-capped, do so. Recommend you do not turn it on again until this has been accomplished.
Since the 20 is a TRF receiver there are fewer things to check. One thing it could be is your output transformer (#29) . Check it for continuity from plate to plate of your 71 tubes. Do this with the speaker plugged in to the chassis.
Next check your SP-PPG interstage transformer secondary (#22). You should have continuity from grid to grid of your 71 tubes.
Another common issue the model 20s have is the antenna/volume control circuit. The volume control (#1) has two sections, one should measure 250 ohms, the other should be 5000 ohms.
RE: Philco 20 Dead - by Elijah - 01-02-2013, 10:14 PM
RE: Philco 20 Dead - by TA Forbes - 01-02-2013, 10:28 PM
RE: Philco 20 Dead - by Joe - 01-02-2013, 11:41 PM
Philco 20 Voltages?? - by Joe - 01-13-2013, 06:31 PM
RE: Philco 20 Voltages - by Ron Ramirez - 01-13-2013, 07:19 PM
RE: Philco 20 Voltages - by Joe - 01-13-2013, 07:37 PM
RE: Philco 20 Voltages - by Ron Ramirez - 01-13-2013, 08:07 PM
RE: Philco 20 Voltages - by Joe - 01-13-2013, 08:17 PM
RE: Philco 20 Voltages - by Ron Ramirez - 01-13-2013, 08:23 PM
RE: Philco 20 Voltages - by Joe - 01-13-2013, 08:31 PM
RE: Philco 20 Voltages - by Ron Ramirez - 01-14-2013, 06:35 AM
RE: Philco 20 Voltages - by Joe - 01-16-2013, 03:00 PM
RE: Philco 20 Voltages - by codefox1 - 01-16-2013, 07:05 PM
RE: Philco 20 Voltages - by Joe - 01-16-2013, 09:00 PM
RE: Philco 20 Voltages - by TA Forbes - 01-16-2013, 09:59 PM
RE: Philco 20 Voltages - by Joe - 01-16-2013, 10:47 PM
RE: Philco 20 Voltages - by TA Forbes - 01-16-2013, 11:27 PM
RE: Philco 20 Voltages - by Joe - 01-17-2013, 12:10 AM
RE: Philco 20 Voltages - by 7estatdef - 01-17-2013, 06:16 PM
RE: Philco 20 Voltages - by Joe - 01-18-2013, 12:46 PM
RE: Philco 20 Filter Caps?? - by codefox1 - 01-18-2013, 09:02 PM
RE: Philco 20 Filter Caps?? - by Ron Ramirez - 01-18-2013, 09:38 PM
RE: Philco 20 Filter Caps?? - by Joe - 01-19-2013, 12:28 AM
There are currently 10882 online users. [Complete List]
» 3 Member(s) | 10879 Guest(s)
