Philco Mod. #44" Need help"
#37
Thanks Jerry, I'll give that a try. I do have one question. In the picture I posted on page two of this thread, on the speaker you see the output transformer on the speaker frame. It has 6 six seperate solder tabs comming off the primary side. Three on top and three on bottom, under each tab is a number. On the top tabs its #5 , 10, and the letter C. on the bottom tabs its 2.5 , 1.25, and .62 . Is there a way to determine which wires go to which tabs? There is 3 wires on a 4 pin plug that go into a socket on the back of the chassis with one pin out hole blank. Inside the chassis I see one wire goes directly to #80 tube from one pin hole. pin hole 2 has 2 wires ,one going to 42 tube and one going to a cap and to ground of chassis via the bc resistor. the third pin hole has one wire going to junction tab and on to the #42 tube. Looking at the schematic its not clear to me where to connect the 3 speaker wires to the output transformer.Sorry to be so long winded just trying to be clear on my question.
Philco Mod. #44" Need help" - by KCMike - 11-27-2012, 11:51 AM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-27-2012, 03:08 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-27-2012, 04:12 PM
RE: Philco Mod. #44" Need help" - by Steve Davis - 11-27-2012, 04:51 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-27-2012, 05:05 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-27-2012, 11:46 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-28-2012, 01:22 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-28-2012, 05:40 PM
RE: Philco Mod. #44" Need help" - by KCMike - 11-28-2012, 06:04 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 11-29-2012, 02:34 AM
RE: Philco Mod. #44" Need help" - by KCMike - 11-29-2012, 11:09 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-10-2012, 06:12 PM
RE: Philco Mod. #44" Need help" - by 7estatdef - 12-10-2012, 07:11 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-10-2012, 07:28 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-16-2012, 11:55 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 12-17-2012, 11:55 AM
RE: Philco Mod. #44" Need help" - by KCMike - 12-18-2012, 11:45 PM
RE: Philco Mod. #44" Need help" - by TA Forbes - 12-19-2012, 01:44 PM
RE: Philco Mod. #44" Need help" - by codefox1 - 12-19-2012, 02:30 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-19-2012, 04:01 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-20-2012, 12:29 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 07:59 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 08:26 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 08:56 PM
RE: Philco Mod. #44" Need help" - by KCMike - 12-22-2012, 09:37 PM
RE: Philco Mod. #44" Need help" - by Ron Ramirez - 12-31-2012, 05:54 PM
RE: Philco Mod. #44" Need help" - by KCMike - 01-01-2013, 04:02 PM
RE: Philco Mod. #44" Need help" - by codefox1 - 01-02-2013, 04:13 PM
RE: Philco Mod. #44" Need help" - by KCMike - 01-02-2013, 08:22 PM
RE: Philco Mod. #44" Need help" - by KCMike - 01-03-2013, 11:26 AM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10758 online users. [Complete List]
» 2 Member(s) | 10756 Guest(s)
