what type is this?
I would not be so negative. Any value to collectors? Absolutely none. Any value to you due to your relationship to it, you decide. Keep it if it has value to you. Sound wise, probably blows away any of the stuff most of us collect. I realize you were not particularly asking about value but model number/brand. To answer those questions, we would need some close up pictures of the control section and some looking at the back of the cabinet for that type of information.
Jerry
what type is this? - by raccrov1991 - 01-01-2013, 06:01 PM
RE: what type is this? - by Arran - 01-01-2013, 11:25 PM
RE: what type is this? - by AI2V - 01-02-2013, 12:50 PM
RE: what type is this? - by raccrov1991 - 01-02-2013, 01:56 PM
RE: what type is this? - by codefox1 - 01-02-2013, 03:57 PM
RE: what type is this? - by wa2ise - 01-02-2013, 08:54 PM
RE: what type is this? - by jerryhawthorne - 01-03-2013, 10:00 PM
Philco 91 Tuning Condenser
