Another British Philco
Arran, you had asked for chassis photos of this 261. Here you go, starting with a front view:
[Image: http://philcoradio.com/images/phorum/261...165fbd.jpg]
Looks just like a 60 chassis, save for the shadowmeter and three gang tuning condenser.
The dial scale is interesting. This is a set designed for AM and long wave reception, yet the dial scale shows the long wave frequencies as 1.7, 1.8, etc. instead of 170, 180, etc.
Now, a back view:
[Image: http://philcoradio.com/images/phorum/261...0326a9.jpg]
Notice the "gramophone" jack at the right, on top, close to the rear of the chassis. There is also a voltage change switch behind the power transformer. It is not switchable to the American 120 standard, unfortunately, so if I restore this set I'll have to run it through a 120-240 step-up transformer or replace the power transformer for one designed with a 120 volt primary. I think that due to the relative rarity of this set, I prefer the former.
I have not looked at all of the valves as of yet. The 80 rectifier is a USA Philco tube, but the date code is 4th quarter 1935 so it is a replacement since this set would have been off the market by then. The 42 is a British Brimar valve.
There was once a sticker on the left rear of the chassis, but it is now gone:
[Image: http://philcoradio.com/images/phorum/261...35566c.jpg]
I can only assume this was made before Philco began to use metal tags on the sets built in Philadelphia for export.
Finally, let's take a look under the chassis:
[Image: http://philcoradio.com/images/phorum/261...df29a7.jpg]
Looks very much like a 60 chassis under here, except for the tone control which is a 4-position switch. Model 60 sets have two-position tone control switches.
Another British Philco - by Arran - 11-08-2012, 12:58 AM
RE: Another British Philco - by Ron Ramirez - 11-09-2012, 07:50 PM
RE: Another British Philco - by Arran - 11-09-2012, 11:55 PM
RE: Another British Philco - by Ron Ramirez - 11-10-2012, 12:09 AM
RE: Another British Philco - by Arran - 11-10-2012, 01:25 AM
RE: Another British Philco - by Ron Ramirez - 11-10-2012, 09:22 AM
RE: Another British Philco - by TA Forbes - 11-10-2012, 01:15 PM
RE: Another British Philco - by Ron Ramirez - 11-10-2012, 02:15 PM
RE: Another British Philco - by TA Forbes - 11-10-2012, 10:21 PM
RE: Another British Philco - by Arran - 11-11-2012, 01:16 AM
RE: Another British Philco - by Ron Ramirez - 11-20-2012, 06:39 AM
RE: Another British Philco - by 7estatdef - 11-20-2012, 08:53 AM
RE: Another British Philco - by TA Forbes - 11-21-2012, 11:55 AM
RE: Another British Philco - by Ron Ramirez - 01-04-2013, 07:46 PM
RE: Another British Philco - by Ron Ramirez - 01-04-2013, 08:28 PM
RE: Another British Philco - by Ron Ramirez - 01-04-2013, 08:41 PM
RE: Another British Philco - by wa2ise - 01-04-2013, 09:55 PM
RE: Another British Philco - by Arran - 01-04-2013, 11:00 PM
RE: Another British Philco - by Arran - 01-04-2013, 11:14 PM
Philco 91 Tuning Condenser
There are currently 5351 online users. [Complete List]
» 1 Member(s) | 5350 Guest(s)
