Model 95 Speaker Help
Hi
The Model 95 originally used a Philco type G speaker - 3200 ohm field coil, push-pull output transformer, 0.7 ohm voice coil impedance. This speaker is also used in Models 65, 76, 87.
Speakers from the following models will also work, but you will have to replace the speaker plug with the large type as used in your set:
77, 96, 111, 112
A 112 speaker will sound the best due to the open-type spider used inside the voice coil, allowing for greater flexibility and, hence, better overall fidelity.
Model 95 Speaker Help - by dskolb - 01-06-2013, 07:24 PM
RE: Model 95 Speaker Help - by TA Forbes - 01-06-2013, 07:31 PM
RE: Model 95 Speaker Help - by Ron Ramirez - 01-06-2013, 07:32 PM
RE: Model 95 Speaker Help - by dskolb - 01-06-2013, 07:38 PM
RE: Model 95 Speaker Help - by Ron Ramirez - 01-06-2013, 07:43 PM
RE: Model 95 Speaker Help - by Arran - 01-06-2013, 07:59 PM
RE: Model 95 Speaker Help - by dskolb - 01-06-2013, 09:20 PM
RE: Model 95 Speaker Help - by TA Forbes - 01-06-2013, 09:56 PM
RE: Model 95 Speaker Help - by Jayce - 01-06-2013, 10:08 PM
RE: Model 95 Speaker Help - by TA Forbes - 01-06-2013, 10:25 PM
RE: Model 95 Speaker Help - by Arran - 01-07-2013, 12:18 AM
Philco 91 Tuning Condenser
