Stewart Warner is here
It's really a beauty!!!! The cabinet is very nice except for the top where the finish is cracking. A little help from MR Mohawk and it will be looking good. I really want to here is bad boy play with it's dual speakers and P/P 6L6's. It has an RF stage and 2 IF amps so should be good in the hearing dept with good selectivity. It even has a fuse on the chassis next to the power transformer. Have a look!
http://www.flickr.com/photos/53710524@N0...hotostream
Stewart Warner is here - by 7estatdef - 01-06-2013, 07:59 PM
RE: Stewart Warner is here - by Gene Pederson - 01-06-2013, 09:14 PM
RE: Stewart Warner is here - by Jayce - 01-06-2013, 09:41 PM
RE: Stewart Warner is here - by TA Forbes - 01-06-2013, 10:07 PM
RE: Stewart Warner is here - by Arran - 01-07-2013, 01:18 AM
RE: Stewart Warner is here - by radiotvnut - 01-07-2013, 02:03 AM
RE: Stewart Warner is here - by 7estatdef - 01-07-2013, 09:58 PM
RE: Stewart Warner is here - by y2kbruce - 01-08-2013, 05:01 PM
RE: Stewart Warner is here - by TA Forbes - 01-09-2013, 11:46 PM
RE: Stewart Warner is here - by Arran - 01-10-2013, 10:38 PM
RE: Stewart Warner is here - by TA Forbes - 01-11-2013, 12:09 AM
RE: Stewart Warner is here - by LedHed - 01-12-2013, 12:12 AM
There are currently 9437 online users. [Complete List]
» 5 Member(s) | 9432 Guest(s)
AvatarAvatarAvatarAvatar
