Philco 90 rewiring
Here is a list of suggested hookup wire colors from the Radio Daze (http://www.radiodaze.com/) catalog:
BLACK - Grounds & Returns
BROWN - Filaments/Heaters off ground
Red - B+ power supply
ORANGE - Screen Grid
YELLOW - Cathode
GREEN - Control Grid
BLUE - Plate
VIOLET - Power supply, negative leads
GRAY - AC Power lines
WHITE - Bias supply, B minus, C minus AGC
This list may not match the factory wiring, but if you are rewiring the whole radio it's a good template. Good luck, Bob
Robert Chesarek
Renfrew, PA
Philco 90 rewiring - by Guest - 08-25-2007, 06:19 PM
Philco 90 - by radiomikee - 08-27-2007, 10:51 AM
[No subject] - by BOB C. - 09-01-2007, 09:02 AM
[No subject] - by Carl Travis - 09-05-2007, 03:29 PM
Colored Tracers - by Raleigh - 09-24-2007, 11:26 AM
[No subject] - by Ron Ramirez - 09-30-2007, 11:33 AM
[No subject] - by 49Stude63 - 09-30-2007, 11:44 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
There are currently 3398 online users. [Complete List]
» 1 Member(s) | 3397 Guest(s)
