Hi, Hi, Miss Canadian Pye!
I'm working on a private sale with the seller, the biggest issue is how to get it to me, it's big, heavy, and not worth a lot, so spending another $28 on shipping was not really justified, especially if the radio got damaged on the way here. He listed it for sale again but the shipping exceeding the value is why nobody else wanted it, so no bids. I was going to get my brother in law to pick up as he was visiting the seller's area for New Years after leaving my place, but he left here with a full load after Christmas so no go there.
Hi, Hi, Miss Canadian Pye! - by Arran - 12-02-2012, 03:27 AM
RE: Hi, Hi, Miss Canadian Pye! - by TA Forbes - 12-02-2012, 01:34 PM
RE: Hi, Hi, Miss Canadian Pye! - by morzh - 12-02-2012, 08:51 PM
RE: Hi, Hi, Miss Canadian Pye! - by Gene Pederson - 12-29-2012, 02:17 AM
RE: Hi, Hi, Miss Canadian Pye! - by Gene Pederson - 12-29-2012, 02:19 AM
RE: Hi, Hi, Miss Canadian Pye! - by Gene Pederson - 01-07-2013, 01:29 AM
RE: Hi, Hi, Miss Canadian Pye! - by Arran - 01-07-2013, 01:39 AM
There are currently 10399 online users. [Complete List]
» 2 Member(s) | 10397 Guest(s)
