General Electric models A-205 & A-208
This model had rated 40 Watt output delivered to two 11" speakers.
It also used a unique switching arrangement to allow defeat of the superhet function and go to a TRF circuit (only on broadcast band), for ultimate wideband performance.
I have never seen any other radio of the age use this design.
The slightly later "A-205/8E" model was bi-amped, with 10 more watts for just the tweeters.
It probably gave the Strat and Masterpiece a run for their money in terms of sound.
Dennis
Pacing the cage...
RE: General Electric models A-205 & A-208 - by Conelrad - 01-08-2013, 01:48 AM
There are currently 7227 online users. [Complete List]
» 1 Member(s) | 7226 Guest(s)
