Stewart Warner is here
The Wells-Gardner 2DL series often used two speakers. They were similar in many ways to your S.W.
You find the 2DL chassis in Coronado, Airline, Truetone, and, of course, W.G. sets. They range from 20 to 30 watts output.
Funny thing... with the exception of the Airline movie-dial sets that used this chassis, you often find them for VERY cheap. In fact, a Truetone model recently sold on eBay for 80.00!!
Stewart Warner is here - by 7estatdef - 01-06-2013, 07:59 PM
RE: Stewart Warner is here - by Gene Pederson - 01-06-2013, 09:14 PM
RE: Stewart Warner is here - by Jayce - 01-06-2013, 09:41 PM
RE: Stewart Warner is here - by TA Forbes - 01-06-2013, 10:07 PM
RE: Stewart Warner is here - by Arran - 01-07-2013, 01:18 AM
RE: Stewart Warner is here - by radiotvnut - 01-07-2013, 02:03 AM
RE: Stewart Warner is here - by 7estatdef - 01-07-2013, 09:58 PM
RE: Stewart Warner is here - by y2kbruce - 01-08-2013, 05:01 PM
RE: Stewart Warner is here - by TA Forbes - 01-09-2013, 11:46 PM
RE: Stewart Warner is here - by Arran - 01-10-2013, 10:38 PM
RE: Stewart Warner is here - by TA Forbes - 01-11-2013, 12:09 AM
RE: Stewart Warner is here - by LedHed - 01-12-2013, 12:12 AM
There are currently 10519 online users. [Complete List]
» 2 Member(s) | 10517 Guest(s)
