Federal Telephone and Radio Corp. E1025TB - Glass Dial Scale
Will have picture or diagram of glass dial scale. Thanks.
Federal Telephone and Radio Corp. E1025TB - Glass Dial Scale - by henrypal - 01-11-2013, 04:38 PM
There are currently 7284 online users. [Complete List]
» 1 Member(s) | 7283 Guest(s)
